troncho10
כל מה שפורסם על ידי troncho10
  1. עריכה: מצטער הכפתור עריכה מנוטרל לא יודע למה אבל יש שינוי: את הPOLK אני לא קונה ומחליף אותם בKENWOOD KENWOOD KFC-P709PS 6-½" 2-Way Component System 6 1/2" Performance Series 2-Way Car Component System Peak: 560 watts per set / 280 watts each side RMS: 160 watts per set / 80 watts each side Impedance: 4 ohms Sensitivity: 86 dB Frequency Response: 63-24,000 Hz Diamond Array Pattern polypropylene woofer Urethane foam surround 1" Soft dome tweeter Swivel tweeter mount In-line crossover network (4900 Hz) Woofer top-mount depth: 2-3/16" Fits also in 6-3/4" openings
  2. Dual BP1204 12-Inch 1100-Watt Illumination: BP1204 Specs Watts RMS: 600 watts Watts Peak: 1,100 watts Sensitivity: 89 dB Frequency Response: 25 to 200 Hz Impedance: 4 ohms Height: 14.2 inches Width: 29.5 inches Depth: 14.2 inches Polk Audio DB6501 6.5-Inch 2-Way Component System Overall Frequency Response: 35Hz-23kHz Nominal Impedance: 4 Ohms Power Handling (continuous): 100 Watts Power Handling (peak): 300 Watts Efficiency: 92 dB Polk Audio DB651 6.5-Inch Coaxial Speakers 6-1/2" 2-way car speakers (pair) supplied adapter rings allow for fit into 6-3/4" locations Dynamic Balance polymer/mica composite woofer with butyl rubber surround 3/4" liquid-cooled silk/polymer composite dome tweeter Neodymium tweeter magnet Kapton voice coil ABS wheel-design grilles Stainless steel mounting hardware Certified for marine use Power range: 6-60 watts RMS (180 watts peak power) Frequency response: 35-22,000 Hz Sensitivity: 92 dB Top-mount depth: 1-11/16" Warranty: 1 year איזה מגבר אני צריך? האם הרמקולים יתאימו העוצמה לסאב? האם הגודל של הרמקולים מתאים לשברולט קאפטיבה? תודה רבה
