yoelcool
כל מה שפורסם על ידי yoelcool
  1. פסלו לי את הרשיון לפני שישה חודשים ואני לא יודע מה לעשות? מה זה מכון 4 וועדת ערר מה צריך לעשות?
  2. אני חושב ללכת על המאזדה לאנטיס 1999 ידני 1600
  3. יעוץ לקנית רכב ב24 עד 35 אלף שקל רכב סטייל
  4. Rockford T400-2 Rockford T400-2 תאור המוצר ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Rockford T400-4 Rockford T400-4 תאור המוצר +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Rockford T152S תאור המוצר ++++++++++++++++++++++++++++++++++++++++++++++++++ Rockford Fosgate Power Series T215D4 15" Dual voicecoil 4 ohm Subwoofer Features: Dual 4 ohms 15" Power Stage 2 Subwoofer Anodized aluminum voice coil former / flat edge wound aluminum wire / copper clad aluminum wire High excursion thermo-rubber surround Precision cast and vented aluminum alloy basket Mirror image symmetrical spiders Parabolic triangular cone geometry support system Massive triple stacked magnet motor assembly Removable and reversible screw concealing ring Power Handling: 1000 watts RMS 2000 watts Peak [*]Sensitivity: 87 dB [*]Mounting Depth: 9.875" [*]Motor Size: 304 oz. triple stacked (Very heavy sub!) +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ T1693C 6X9 inch 4 way Injection Molded Polypropylene Woofer Cone Woofer surround Polyurethane Tweeter Size 1 in. and .5" SuperTweeter Woofer dimensions Mounting Depth Bottom - 3.0 in. Power Handling (RMS) - 110 watts Power Handling (Peak) - 210 watts Frequency Response - 40-22k hz Sensitivity - 90 db +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 3Sixty Series 3SIXTY.1Interactive Signal Processor & OEM Interface (Patent Pending) The 3Sixty.1 is the most advanced OEM integration processor on the market. Its advanced artificial intelligence allows the use of aftermarket car audio equipment to be utilized with virtually any OEM source unit. In addition, auto-equalization processes overcome and correct for OEM response inadequacies. There's also an auxiliary input for an iPod or other external audio device. 3Sixty Series 3SIXTY.1Interactive Signal Processor & OEM Interface (Patent Pending) The 3Sixty.1 is the most advanced OEM integration processor on the market. Its advanced artificial intelligence allows the use of aftermarket car audio equipment to be utilized with virtually any OEM source unit. In addition, auto-equalization processes overcome and correct for OEM response inadequacies. There's also an auxiliary input for an iPod or other external audio device. פלוס מערכת של פיוניר P8850 MP3 +++++++++++++++++++++++++++ 3sixty1 ןאם אני צריך להוסיף משהו תגידו לי בבקשה כל המערכת של רוקפורדPOWER
  5. אז מה אתה אומר אחי אולי זה מה חוט של הגז אולי אחי אני מנסה לעזור לו אתה מבין או שילך למוסך שלו ויבדקו לו את העינין
  6. ניראלי אתה צודק אחי גם לי יש פורד פיאסטה 2001 ואחד וגם לי היה את זה וגם שזה על נוטרל הטורים עולים
  7. אני חושב שמי שפתח את הפורם הוא בן אדם אמין וטוב ואני מעריך את התכנון ואת האנשים החברים כמוני ויודעים מה לעשות בכל מצב זה אתר מעולה אכשוו אני יתכיל אני בן 19 וחצי מכונאי רכב אני חולה על כל מה שקשור לרכב
