חפשתי קצת ומצאתי מישהו שכתב לכוון את המערכת ככה ...
עכשיו השאלה שלי אם לכוון ככה ולהשאיר את המגבר על הכי חלש בכייון של ה (100 מילי וולו)level input ו preq עם על 32hr ?
Subwoofer setting 1: Off, Normal, Reverse (???)
This setting depends on the box design and the way the port is tuned. If it is a sealed box, then it is normally advised to never play on REVERSE mode. Else, you can try for the best option by trial and error.
Subwoofer setting 2: 50-125 Hz ; -24 to +6
80Hz is the safest and best bet. Leave the SUB level to +2 or +4 as maximum. If the amp is tuned well, then 0 is the best.
EQ setting 1: Low (-6 to +6) Mid (-6 to +6) Hi (-6 to +6)
LOW can be set to +levels. MID is best left at 0. HI can be set to - levels or zero as it may turn very bright on higher levels.
EQ setting 2: Low 40-160 Hz ; Q1W,Q2W,Q1N,Q2N
Low is best at 100 or 80. Sometimes, 125 but not higher. Q1N or Q2N
Mid 200-2,000 Hz ; Q1W,Q2W,Q1N,Q2N
.5k to 1k. Q1W
High 3,000-12,000 Hz ; Q1W,Q2W,Q1N,Q2N
10k. Q1N
Loudness: Low, Medium, High
Medium
Bass: 0 to +6
0 - +2
SRC LV Adjust: "SLA 0 to +4"
0 - +2
High Pass Filter: 0 to 125 Hz
80hz
