שלום,
האם המכשיר הזה יעבוד בארץ?
להלן הפרטים:
Car HD DVB-T Receiver with MPEG4/H.264 with 2 tuner,3 Video Output
Support HE-ACC/H.264/AVC,MPEG2-4 Video Decode
Available to upgrade the fireware via USB slot
Standard for DVB-T and MPEG2
Auto searching and updating bit rate information
Storage for 1000pcs channels
Memory function after power offSupport OSD teletext
Support multi language: Arabic, Danish, English, Estonian, French, Germany, Greek, French, Hebrew,Indonesian, Spainish, Romanian, Slovak, Swedish, or do what you need
EPG program guide and PIG(Picture in Graphics )Function
Audio-R, Audio-L output16. Support IR output and extended remote sensor receiver
7MHz, 8MHz Bandwide
HDMI output: 1280x720p 1920x1080i
Three Video output and two audio output
Specifications
Input frequency
VHF 177.5MHz - 226.5MHzUHF 474MHz - 858MHz
Modulate
QPSK/16 - QAM/64-QAM
Decode standard
MPEG2,MP@ML,MP@HL,H.264/AVC
Audio decode standard
MPEG-1, MPEG-2,layer and 2, MPEG-4, HE-AAC
3 Way Video Output
Output Resistance: 75 ohm
Output Voltage: 1.0 +/_ 2.0mVp-p
Audio output: 2Vp-p
Power Supply
DC 12V 8W
Connecting Terminal
External antenna input jack, Quadrate car power input jack,Audio/Video, Audio/Video(AV) output jack, Extern remote control cord jack, external power supply input jack, USB upgrade socket, High-definition output interface.
Applicable Power Supply
Car storage battery (12V)
Outer demension
178mm*116mm*26mm
Application Temperature
-5 ~40 degree
Storage Temperature
-20~60 degree
תודה רבה לעוזרים
