למכירה:
1. רדיאו דיסק Alpine-cda7990 מסידרה F1 Status
Sampling Rate ..........................................................................................44.1kHz
Signal-to-Noise (S/N)...............................................................................120.0 dB Channel Separation (1kHz)........................................................................110.0 dB Dynamic Range (1kHz) .............................................................................100.0 dB Total Harmonic Distortion (THD).....................................................................0.002% Frequency Response .............................................................................5-20k ±1 dB Number of DACs ................................................................................................3 DAC Type ......................................96kHz/24Bit Sign Magnitude (Burr-Brown K-Grade) Oversampling ...................................................................................8X/352.8kHz Wow & Flutter (%WRMS) ................................................................................B.M.L
2. מעבד Alpine Pxa-h900 מסידרה F1 Status
EQ number of bands: Front: 31
Rear: 31 Center: 31 Subwoofer: 10 Graphic equalizer boost cut range: ±9 dB Time correction control range: 0 to 20 ms (0.1 ms steps) Frequency response: 20 Hz to 20 kHz S/N ratio: 110 dB Channel separation: 80 dB Input sensitivity: 850 mA (2V for analog 1 only) Subwoofer crossover: 20 to 200 Hz (1/6 oct. steps) Subwoofer level control: 0 dB to +15 dB Rated output: 4V (with 10 k ohms load) Input impedance: 10 k ohms or greater Output impedance: 1 k ohm or less
3.מגברים מקצועים McIntosh MCC204,MCC302
http://www.mcintoshlabs.com/mcprod/..%5Cdata%5Cmanuals%5CMCC204om.pdf
http://www.mcintoshlabs.com/mcprod/..%5Cdata%5Cmanuals%5CMCC302om.pdf
4. סאב JL Audio 12W7
http://mobile.jlaudio.com/products_subs.php?series_id=9
5. קומפוננט Focal 165w3 Utopia
http://www.unbeatablecaraudio.com/focal/utopia_speakers.htm
6. 3 קבלים Stinger כל אחד 1F.
http://www.ryda.com.au/ProductDetails.asp?ProductCode=SC201B
לפרטים: 050-6922762
