cocAIn
כל מה שפורסם על ידי cocAIn
  1. מפרט טכני: Fully motorized D Mask+ with Mask key 4 x 50 W 3 preouts RDS Tuner 3 colour, Full DOT FL display DMask+ MP3 decoder built-in Rotary volume control Changer control Remote control included 4 x 50 Watt max output power 3 RCA preouts, 4.5 Volt Separated tone control: Bass/Mid/Treble Source tone memory / Loudness control Rotary volume control System Q-EX: preset & full manual sound control AUX-in with optional unit (CA-C1AX or KCA-S210A) System E’s (built-in easy LPF & HPF) Bass Management System with compatible amp. Dual zone source & volume control K3I clean reception tuner RDS Tuner with Radio Text 24 presets: 18 FM, 6 MW & LW Auto memory entry (AME) Up/down seek tuning / Local Seek Stereo/Mono selector Auto1/Auto2/Manual tuning mode DAB reception with optional unit KTC-9090DAB CD-R/RW ready MP3 decoder built-in with support of ID-3 Tag MPEG-1.0/2.0/2.5 Audio layer-3 Random/Repeat/Scan function CD-Text ready 0-bit mute (L&R independent) 8 times over-sampling 1 bit D/A converter S/N ratio: 105 dB Dynamic range: 93 dB Channel separation: 95 dB Dual changer control capability (CH1/CH2 & AUX) CD-text with compatible units DNPS (Disc Name Preset) with compatible units DNPP (Disc Name Preset Play) by remote control Direct access with remote control Disc & Track repeat Disc & Track scan Disc & Magazine random play Fully motorized D Mask+ with Mask key Motorized angle adjustment Protection case for faceplate 3D Multicolour FL display (4-tone) Selectable key illumination (Red or Green) Digital clock (24H) / Auto dimmer All Off select (20/40/60 minutes) Built-in fuse/coil 2-way telephone mute Memory Calendar External option control OEM display out OEM steeringwheel wired remote input Kenwood H/F GSM interface with optional unit Remote control included (RC-420) מכשיר פשוט סוף הדרך! רציניים בלבד לפרטי!
  2. הסאבים במצב מעולה! בעליי הספק של 800W ו400RMS נקי! נמכרים בגלל שהרכב שלי נגנב ואין לי כרגע תוכניות לקנות רכב חדש! בשימוש כחצי שנה ומיועדים לאנשים שמבינים עניין! מחירם 850¤.
  3. guyl שאתה אומר "יקר" אתה יכול לפרט קצת יותר במספרים?
  4. או שיש אחוזים מסויימים בלבד שהרכב נפגע והתקן מאשר החזרתו לכביש?
  5. אמרו לי שתוסף יכול לפתור את הבעיה,האם זה נכון?
  6. יש לי סיטרואן סקסו 1.4 מודל 98. משום מה אני לא יודע למה הצריכת דלק מאוד גבוהה,מה יכולה להיות הסיבה?האם אנשים שמכירים את האוטו יכולים להעיד על צריכת דלק גבוהה של האוטו? ברגע שעובד המזגן הרבה זמן יחסית פתאום מופיעה הנורית K- בלוח שעונים.אחרי זה אני מחנה את האוטו לכ20 דקות ,מתניעה ואין כבר נורית ושוב צריך לנסוע הרבה זמן יחסית עם מזגן עד שנדלקת הנורית הזאת,מה לעשות ואיך לגרום לנורית להפסיק לדלוק?
  7. ספי,אבא שלי שהוא בעל הרכב,לא נוגע בכלום הוא עושה פשוט הכל במוסך.
  8. בדיקה במוסך של VOLVO בהרצליה העלתה בעיה בגיר שמצריכה שיפוץ. כל הטיפולים נעשים באופן שוטף במוסך ככה שאם יש צורך בשמן גיר חדש או משהו זה נעשה בטיפולים תקופתיים. הנזק שהם העמידו בפניי הוא 10,000 ¤ יכול להיות שגם 8.האם זה הגיוני שאוטו יד ראשונה שעשה 120K קילומטר וטופל תמיד בזמן במוסך מגיע למצב שהלך לו הגיר?! והאם המחיר הוא לא שחיטה?
  9. ברגע ההתנעה הגיר עובד חלק,אחרי כ50 מטר הוא מחליק לבד ומעביר לניוטרל. הגיר הוא אוטומטי והאוטו הוא VOLVO S40. האוטו עבר סה"כ 120K קילומטר. האם לדעתכם הבעיה היא בחיישן או בגיר עצמו? תודה רבה.
  10. עכשיו כבר הוא משלם חצי שנה נשאר לו עוד שנתיים
  11. *********נמחק ציטוט מיותר*************** לא בקטע.
  12. יש לך זיכרון טוב אתה.... כן זה אותו אחד,ואני עוזר לו כל הזמן לצאת מהבוץ.קצת מתחילים להניע את העגלה,בום מגיע חוב חדש!
  13. מכוניות שנמכרות לפירוק או לגריסת ברזל לעולם לא נעשות עם חוזים או משהו כזה אי אפשר להוכיח כלום במצב שכזה.
  14. השאלה שלי אם יש אפשרות להפחית בקנס?
  15. זה מה שרציתי לברר,ידוע לך על גובה הקנסות?
  16. יכול להיות שעשו עליו קומבינה,כי הוא מכר את הרכב לפירוק ומרוב טיפשותו לא הוריד את המספרים
  17. חבר שלי קיבל חוב לכביש 6 דרך הוצל"פ על נסיעה בין השנים 2003-05 בכביש 6. מדובר על 35 נסיעות שסה"כ החוב כולל ריביות וקנסות אדירים על סך 6,700¤!!! ברגע שהתקשרנו למוקד של כביש 6,אמרו לנו שאין מה לפנות לכביש 6 אלא רק להוצל"פ כי התיק אצלהם. חבר שלי עבר דירה ושום חוב של כביש 6 לא הגיע לכתובת החדשה שלו שמעודכנת במשר הפנים אבל לא מעודכנת במשרד הרישוי ובכביש 6 שולחים רק לכתובת שמצויינת במשרד הרישוי. מה ניתן לעשות בנושא זה?האם מישהו נתקל בעבר במקרה דומה ויכול לייעץ? באמת שיש צורך במישהו שיכול לעזור כי הבן אדם גם ככה שקוע בחובות להוצל"פ מפה ועד כנרת תודה רבה מראש לכל עוזר!
  18. cocAIn
    נגנב לי הרכב אתמול :(
    באוטו הבא שלי בע"ה אני שם רב בריח על הידית הילוכים ומנעול הגה
  19. cocAIn
    פיאט פונטו
  20. cocAIn
    איפה מצאו?
  21. cocAIn
    קודן ברכב ואזעקה זהו.
  22. cocAIn
    זה בסדר,כבר מאוחר לחפש את האוטו כי הודיעו באמצעות קשרים במשטרה שהרכב כבר הועבר לשטחים
  23. הלכתי למשטרה להגיש תלונה הרבה זמן ישבתי כמו מפגר ורק לפני שבועיים עשיתי חובה ומקיף עשיתי טסט לשנה וטיפול בעעעעעעע איזו נפילה מה עכשיו?כמה זמן אני צריך לקבל את הכסף מביטוח איך הולך כל התהליך הזה בכלל?
  24. שאתה אומר אחזקה שוטפת יותר יקרה סדר גודל של כמה ¤ הבדל בממוצע שנתי?
  25. מה לדעתכם כדאי לקנות מכל הבחינות? מוסך,דלק,נהיגה וכ"ד. האם על הרנו חוגגים הרבה יותר מאשר על ההונדה? אשמח לקבל את כל הפרטים. תודה
