להלן מצורפות ההוראות של פיוניר.
בכל מקרה, עם המערכת אתה אמור לקבל גם הוראות בעברית. לחץ על הלינק כדי להוריד את התוכנה.
There are two options when it comes to loading your own OEL image using the OEL Studio.
Option one: Importing your own files (Picture or Video)
1. Open Program, > click on "Make Ent Picture (LKA)",
2. Click the tab "BGP" > choose "Picture to Picture" or "Video to Picture" >Open , select from your jpg folder the jpg file you'll like to create > open
3. Double click on still picture. After you manipulate the picture/movie, move to "Step: edit the image", after editing the picture move to "Step 3: Preview " then click on "Conclude editing/Save". Remember where you save the LKD file.
Next steps are use to convert the LKD images you saved from the step above or you downloaded from http://pioneer.jp/car/pclink4/index-e.html>
4. Click on the "Export" tab> Open. Select the LKD file you save or downloaded (you can select as many as you like and can mix type.
5. Select one or all file names from "Step1: Select a file" box then click " -> Move".
6. Click the "LKA file export"
7. Name and save LKA file
8. Use a recording program to record the LKA file to a CD-R or CD-RW.
Step to download the LKA file to the headunit.
1 Press SOURCE and hold until the unit turns off.
2 Press and hold EQ and LIST until the unit goes into download mode.
- Front panel is opened automatically and then Download and Insert disc is displayed.
- If a disc is loaded in the unit, it is ejected automatically.
- When the front panel is open, does not go into download mode even if you press and hold EQ and LIST.
3 Insert the disc containing the rewritten data into the CD loading slot.
- Download Ready appears in the display, and then data rewriting will start automatically.
- Now loading is displayed during rewriting.
4 After Finished is displayed, press EJECT to eject the disc.
- Download mode is exited and unit turns off.
Notes
! Do not insert anything other than a CD into the CD loading slot.
! It can take several minutes to complete this operation.
! During download mode, buttons other than EJECT are inactive.
! To cancel download mode, press EJECT.
! If an error message such as CD ERROR is displayed, refer to Understanding error message on rewriting the entertainment displays on the owners manual.
target=_blank>http://pioneer.jp/car/pclink4/index-e.html>
Notes
