כל מה שפורסם על ידי nadavt
איזה סט קומפוננט עדיף SOUNDSTREAM SC-6T VS MB Quart FSB 216 VS New Crunch P165C
nadavt פרסם הודעה בנושא של nadavt בתוך מכירה - אודיו
אפשר לנעול הועבר לפורום המתאים -
יחובר למערכת בילדאין של סיטרואן סי 4 (לא MP3) ללא מנחת וללא מגבר ישירות לHU, כבמה קדמית בדלתות, איזה מהבאים ייתאים לי ביותר ? הסטים עולים בין 200-335 שח ביבוא אישי כולל מיסים ומשלוח מארהב NEW SOUNDSTREAM® SC-6T 6-1/2" 2-WAY ARACHNID CAR COMPONENT SPEAKERS SYSTEM 6.5 [TABLE=class: cms_table, width: 100%] [TR] [TD=colspan: 2][/TD] [/TR] [TR] [TD=colspan: 2] Key Features [/TD] [/TR] [TR] [TD=width: 35%] Car Speaker Function [/TD] [TD=width: 65%] Mid-Range Speaker, Subwoofer, Tweeter [/TD] [/TR] [TR] [TD=width: 35%] Size [/TD] [TD=width: 65%] 6.5" [/TD] [/TR] [TR] [TD=width: 35%] Type [/TD] [TD=width: 65%] Component Speaker System [/TD] [/TR] [TR] [TD=width: 35%] Elements [/TD] [TD=width: 65%] 2-Way [/TD] [/TR] [TR] [TD=width: 35%] Powered [/TD] [TD=width: 65%] Powered [/TD] [/TR] [TR] [TD=width: 35%] RMS Power [/TD] [TD=width: 65%] 160 W [/TD] [/TR] [TR] [TD=colspan: 2][/TD] [/TR] [TR] [TD=colspan: 2] Technical Features [/TD] [/TR] [TR] [TD=width: 35%] Min Frequency Response [/TD] [TD=width: 65%] 70 Hz [/TD] [/TR] [TR] [TD=width: 35%] Max Frequency Response [/TD] [TD=width: 65%] 20 kHz [/TD] [/TR] [TR] [TD=width: 35%] Impedance [/TD] [TD=width: 65%] 4 ohm [/TD] [/TR] [TR] [TD=width: 35%] Sensitivity [/TD] [TD=width: 65%] 92 dB [/TD] [/TR] [TR] [TD=width: 35%] Peak Power Handling [/TD] [TD=width: 65%] 320 watt [/TD] [/TR] [TR] [TD=colspan: 2][/TD] [/TR] [TR] [TD=colspan: 2] Mounting [/TD] [/TR] [TR] [TD=width: 35%] Enclosure [/TD] [TD=width: 65%] Non-Enclosed [/TD] [/TR] [TR] [TD=width: 35%] Mounting Diameter/Length [/TD] [TD=width: 65%] 6.5 in. [/TD] [/TR] [TR] [TD=colspan: 2][/TD] [/TR] [TR] [TD=colspan: 2] Components [/TD] [/TR] [TR] [TD=width: 35%] Tweeter Design [/TD] [TD=width: 65%] Dome [/TD] [/TR] [TR] [TD=width: 35%] Surround Material [/TD] [TD=width: 65%] Rubber [/TD] [/TR] [TR] [TD=colspan: 2] או New Crunch P165C 6.5" 800W Component Speaker Set 800 Watt 6 1/2" P1-6.5C 55W Continous Power Handling RMS Power Range : 55 Watts Peak Power Handling: 800 Watts Diameter: 6.5 Inch Impact Resistant Tweeter Elements Silver Alpha-Cellulose Cones High Mid-Bass Impact Neo Mylar Soft Dome Tweeter Installation hardware Included Anti-Resonant Stamped Steel Basket Wide Nominal Power Range Spade Speaker Terminals Moisture Resistant Rubber Surround 1 Year Manufacturer Warranty MB Quart FSB 216 6-1/2" Formula Series 2-Way Component Speakers System Power Handling: Peak: 300 watts per set / 150 watts each side RMS: 80 watts per set / 40 watts each side [*]Dark gray polypropylene cone [*]Butyl rubber surround for smooth speaker response [*]3/4" (19mm) Titanium dome tweeter [*]In-line crossover for accurate frequency separation [*]Woven tinsel leads [*]Progressive grille [*]4 ohms impedance [*]High temperature voice coil [*]Spade speaker terminals [*]Top-mount depth: 2-3/8" [*] Authorized Internet Dealer [*]1-year Manufacturer's warranty [/TD] [/TR] [/TABLE]
יחובר למערכת בילדאין של סיטרואן סי 4 (לא MP3) ללא מנחת וללא מגבר ישירות לHU, כבמה קדמית בדלתות, איזה מהבאים ייתאים לי ביותר ? הסטים עולים בין 200-335 שח ביבוא אישי כולל מיסים ומשלוח מארהב NEW SOUNDSTREAM® SC-6T 6-1/2" 2-WAY ARACHNID CAR COMPONENT SPEAKERS SYSTEM 6.5 [TABLE=width: 100%] [TR] [TD=colspan: 2][/TD] [/TR] [TR] [TD=colspan: 2]Key Features[/TD] [/TR] [TR] [TD=width: 35%]Car Speaker Function[/TD] [TD=width: 65%]Mid-Range Speaker, Subwoofer, Tweeter[/TD] [/TR] [TR] [TD=width: 35%]Size[/TD] [TD=width: 65%]6.5"[/TD] [/TR] [TR] [TD=width: 35%]Type[/TD] [TD=width: 65%]Component Speaker System[/TD] [/TR] [TR] [TD=width: 35%]Elements[/TD] [TD=width: 65%]2-Way[/TD] [/TR] [TR] [TD=width: 35%]Powered[/TD] [TD=width: 65%]Powered[/TD] [/TR] [TR] [TD=width: 35%]RMS Power[/TD] [TD=width: 65%]160 W[/TD] [/TR] [TR] [TD=colspan: 2][/TD] [/TR] [TR] [TD=colspan: 2]Technical Features[/TD] [/TR] [TR] [TD=width: 35%]Min Frequency Response[/TD] [TD=width: 65%]70 Hz[/TD] [/TR] [TR] [TD=width: 35%]Max Frequency Response[/TD] [TD=width: 65%]20 kHz[/TD] [/TR] [TR] [TD=width: 35%]Impedance[/TD] [TD=width: 65%]4 ohm[/TD] [/TR] [TR] [TD=width: 35%]Sensitivity[/TD] [TD=width: 65%]92 dB[/TD] [/TR] [TR] [TD=width: 35%]Peak Power Handling[/TD] [TD=width: 65%]320 watt[/TD] [/TR] [TR] [TD=colspan: 2][/TD] [/TR] [TR] [TD=colspan: 2]Mounting[/TD] [/TR] [TR] [TD=width: 35%]Enclosure[/TD] [TD=width: 65%]Non-Enclosed[/TD] [/TR] [TR] [TD=width: 35%]Mounting Diameter/Length[/TD] [TD=width: 65%]6.5 in.[/TD] [/TR] [TR] [TD=colspan: 2][/TD] [/TR] [TR] [TD=colspan: 2]Components[/TD] [/TR] [TR] [TD=width: 35%]Tweeter Design[/TD] [TD=width: 65%]Dome[/TD] [/TR] [TR] [TD=width: 35%]Surround Material[/TD] [TD=width: 65%]Rubber[/TD] [/TR] [TR] [TD=colspan: 2] או New Crunch P165C 6.5" 800W Component Speaker Set 800 Watt 6 1/2" P1-6.5C 55W Continous Power Handling RMS Power Range : 55 Watts Peak Power Handling: 800 Watts Diameter: 6.5 Inch Impact Resistant Tweeter Elements Silver Alpha-Cellulose Cones High Mid-Bass Impact Neo Mylar Soft Dome Tweeter Installation hardware Included Anti-Resonant Stamped Steel Basket Wide Nominal Power Range Spade Speaker Terminals Moisture Resistant Rubber Surround 1 Year Manufacturer Warranty MB Quart FSB 216 6-1/2" Formula Series 2-Way Component Speakers System Power Handling: Peak: 300 watts per set / 150 watts each side RMS: 80 watts per set / 40 watts each side [*]Dark gray polypropylene cone [*]Butyl rubber surround for smooth speaker response [*]3/4" (19mm) Titanium dome tweeter [*]In-line crossover for accurate frequency separation [*]Woven tinsel leads [*]Progressive grille [*]4 ohms impedance [*]High temperature voice coil [*]Spade speaker terminals [*]Top-mount depth: 2-3/8" [*]Authorized Internet Dealer [*]1-year Manufacturer's warranty [/TD] [/TR] [/TABLE]
C4 2008 sx. איפה נמצאים המחברים? האם זה פיוז? עוד מידע חשוב - כל פעם שעולים על באמפר או בור התקלה חוזרת. משמע משהו זז שם
שלום חברים מזה שבועים נורת האיתות הימני לא עובדת/ עובדת לסירוגין( קול איתות מהיר). הנורה תקינה לחלוטין. נקנו שתי נורות אוסראם למטרת בדיקה. ברגע שמוציא את הנורה מהתושבת ממתין כמה שניות ומחזיר לבית הנורה ,התקלה מתאפסת.כאמור מדובר באיזה סוג של קצר. אין ניתן לפתור עיניין זה? תודה ושבת שלום
איפוס נורת טיפול (מפתח ברגים) בסיטרואן C4
nadavt פרסם הודעה בנושא של nadavt בתוך טכני, אחזקה וטיפולים
תודה בוקי -
דגם מנוע 1.6 SX משנת 2008 איך ניתן לאפס נורה זו ? תודה
באחת הקבלות של טיפולי הרכב אותו רכשתי מזה שבוע ימים ישנו סעיף שהוחלפה רצועת מנוע. מה הכוונה ,האם הוחפה טיימינג? אין ניתן לוודא זאת ב100 אחוז
מה העלות של האופציה השניה?
שלום חברים בידי רק צרור מפתחות אחד לרכב הנל (משמע מפתח קפיץ מקורי כאשר השלט מובנה בתוכו). איך אני מוזיל \ משכפל את המפתח הנל והציפ שככל הנראה נמצא בשלט ? מצאתי את המוצר הבא באיביי. מפתח תואם לשלי אך מה אני עושה עם השלט עצמו: http://www.ebay.com/itm/Remote-Entry-Key-Fob-Shell-Case-3-Buttons-for-CITROEN-Peugeot-C2-C3-C4-C5-C6-C8-/310757456347?pt=AU_Car_Parts_Accessories&hash=item485a9679db&vxp=mtr אשמח לשמוע את חוות דעתכם
מסמר בגלגל קדמי - אין איבוד אוויר - מה עושים?
nadavt פרסם הודעה בנושא של oron123 בתוך טכני, אחזקה וטיפולים
צמיגי לושי הירקון 21 בני ברק מחיר פנצר 40 שח הכי מקצועי שיש -
1600 סמק שנתון 2008 דגם SX אזור המרכז
שלום חברים בידי הרכב הנ"ל(נרכש אתומול). לרכב 107 אלף ק"מ 6 שנים על הכביש. עפ הוראות יצרן וניסון שלכם, מתי אני אמור להחליף את רצועת התזמון? מה עלות החלקים והעבודה -+ אם יש לכם מוסך מומלץ , לא מחייב מוסך מורשה חברה , אשמח לקבל המלצות אלו תודה נדב
מה לעשות במצב שלמוכר יש רק מפתח אחד , האם לפוצץ עסקה? להחתים על מסמך? האם מבחינת הביטוח זה מהווה בעיה? תודה חברים
מה המחיר של בדיקה לפני קנייה? האם מדובר בבדיקה האמינה בשוק? יש הנחה לחברי הפורום?
שני הדגמים הינם משנת 2007: הסיטרואן זהו דגם SX 1600 אוטומטי בעלת 88 אלף קמ הגרנדה Active Plus אוט' 1.4 89 אלף קמ שתיהן טופלו בחברה. המחיר עבורן עומד באזור ה27K לעולם לא נהגתי על גיר רובוטי בעל מצמד אחד. כיום אני נוהג על פורד פוקוס רובוטית 2012 בעלת 2 מצמדים. אני חושב שהגיר מעולה. מעבר לכך ב4 השנים האחרונות נהגתי על פולו אוטומטית . אני מפחד שהשינוי יהיה דרסטי בין המעבר מהרובוטי לאוטומטי. אשמח לשמוע את דעתם לגבי , צריכת דלק, סטיחות , טיפולים ואחזקת הרכבים הנ"ל.
נתקלתי ברכב הנל עם 90 אלף קמ מליסינג מימוני(פרטי) על פניו נראה שמור מאד. הבחור דורש 29K , שמונה אלפים מתחת למחירון לוי יצחק. כמובן שזה מחיר לפני מיקוח. האם זה מחיר ראוי לרכב שכזה? ממה להיזהר לפני קניה ואילו דגשים לבדוק לפני בדיקה? כאמור יש לי תקציב מקסימום של 25K .
ראיתי איגניס יד 2 פרטית 136 אלף קמ ב26000 שח מה אתם אומרים על הרכב הנל ?
2007-2009 אלו השנתונים שאני מעוניין ליסינג או פרטי קמ עד 130 אלף קמ תקציב עד 25 אלף שח
אני מעוניין לקבל את התמורה הטובה ביותר לכסף...
החלטתי לא לגמור את כל חסכונותי ושוקל לרכוש רכב אותו אחזיק כ4-5 שנים במחציק מהסכום ההשקעה ההתחלתי . העדפה עד מנוע 1600 סמק , האצ'בק, אמינה וחסכונית 1.סיטרואן סי 4 2008/7 2. רנו מגאן האצ'בק 2008/9 3.סיריון 2007 4.פזו 207 5.רנו קליאו 2008 אשמח לתגובות
מי עדיפה, סוויפט 2009 יד1 או מיקרה 2011 יד 2?
nadavt פרסם הודעה בנושא של nadavt בתוך ייעוץ ברכישת רכב
פספסתי. הרכב נמכר ב53 אשח לאחר בדיקה... לא נורא תבוא אחת אחרת אני מאמין שתיהיה ירידת מחירים שבוע הבא בכל קרה... -
הסוויפט עם 90 אלף קמ המיקרה עם 72 קמ על פניו שני הרכבים נראים טוב חיצונית ומכנית. מי עדיפה בכל פרמטר? מתי עושים טיימינג בסוויפט וכמה בערך סה עולה?
